kwano
Perhaps Aflie, Flyer & Silversaloon could assist here.
My W210 facelift model, 2002 E220 CDI Estate (with Multi function steering wheel, MB 6 disc CD changer and factory fitted Nokia 6210 Phone)
I have read various posts and links and just need some confirmation before I make the required connections for my Comand unit 210 820 5489 with CANBUS.
My original C connector (to my Audio 10 unit) is as follows :
Pin 01 – Red / Brown wire – Can Hi
Pin 02 – Brown wire – Can Lo
Pin 03 – Blank
Pin 04 – Blue / Black wire – Wake up D2B for CD Changer
Pin 05 – Black wire - (-)Negative
Pin 06 – Brown wire - (+)Positive
Pin 07 – Blank
Pin 08 – Blank
Pin 09 – Blank
Pin 10 – Blank
Can anyone confirm that the description above is correct for each coloured wire.
The new relevant pin connections layout should I believe be as follows :
C1 Connector :
Pin 05 – (-) Power CD Changer - Black wire - (-)Negative
Pin 06 – (+)Power CD Changer - Brown wire - (+)Positive
C2 Connector :
Pin 04 - Aux in right
Pin 05 - Aux in GND (right)
Pin 06 - Speedsignal - locate & connect green/black wire
Pin 08 - CAN Lo - Connect to Brown wire
Pin 09 - CAN Hi - Connec to Brown/Red wire
Pin 10 - Wake up D2B to CD-changer (to wake up CD changer) - Connect to Blue/Black wire
Pin 13 - Aux in left
Pin 14 - Aux in shield (or aux in GND left)
I think the new connections are as described above. I haven't got the cable/adaptor for the AUX connections yet so won't know the cable colours.
Also I read a post from Paul Grainger back in Jan 2003 that if your car is CANBUS equipped then it may not be necessary to connect the Speedsignal to Pin 06 on the C2 Connector. Any thoughts here guys ?
Oh, just another point. I haven't seen much about connections of factory fit phones to Comand - how does this work and is there any connections I need to make. In the current setup it works off the Audio 10 - I think the connections are from the original A Connector currently as :
Pin 02 - Grey wire
Pin 04 - Red/White stripe wire
Pin 05 - Blue/Whie stripe wire
Pin 08 - Brown wire
Sorry for the lengthy post guys - I just wanted to make sure I didn't miss anything. Thanks all in advance.
Pin 03 – Blank
Pin 07 – Blank
Pin 08 – Blank
Pin 09 – Blank
Pin 10 – Blank
C1 Connector :
C2 Connector :
Pin 02 - Grey wire
Pin 08 - Brown wire
