nippa
- Mar 7, 2017
- Location
- Kent
- R230 SL55 AMG, R230 SL350, W203 C180K, searching for a rustless, unmolested Fiat Barchetta LE.
Hi all,
My Comand 2.0 D2B (standard, non Bose) has had bad distortion since I took my 2003 R230 SL 350 in to the garage and welding took place under the battery tray and the tray was replaced due to a battery acid leak that occured before I owned the car, this may be a co-incidence though but it was fine when I took it in and not when I collected it 3 days later. The right door speaker seems worse that left, hard to tell and hard to know if this is affecting all speakers as I can only fade between left and right. Distortion reduces somewhat when volume is turned up and posibly improves over time on each individual journey, although this may be a figment of my imagination.
I don't think it's the speaker itself, as it appears to affect both channels and turning up the volume seems to sort things, though I'm not sure, I don't want to start buying parts needlessly to go through a process of elimination.
Incidentally, this hs been tested on bluetooth, radio and CD changer and the distortion applies to all.
Thanks for any help you can give.
Mark
Mark
