Comand 2.5 to Television
developer
Volvo V90 D5 AWD
What does COMAND 2.5 need to be TV capable?
A digital TV tuner and aerial connection?
I'm guessing Christmas Eve isn't the best time to ask.
John...is Comand 2.5 standard on 2007 E class? If so I have comand with the rear digital TV I think it has an extra connection at the rear for the TV.
Thanks, I know about Comand what Jeremy Clarkson knows about diplomacy ;).
I need an idiots guide to TV connectivity.
I am not 100% sure but the comand unit from the factory, when ordered with the TV option I believe had an extra connector.
No doubt there is an aftermarket way of making a TV work from it though.
Wait for Alfie and you will get the definative answer.....
If you have NTG2.5 COMAND (i.e hard disk based, from Model Year 2009 onward), then it has the video-in connector.
You will need TV tuner, bracket, fibre, wiring, and antenna amplifiers to connect to the antenna in the car - need to make sure the antenna are actually there of course.
The pre MY2009 E class had NTG1 (with the navigation drive in the boot), and yes, the COMAND unit didn't necesarilly come with the TV connector, and the TV tuner is much more expensive than the newer tuner used in NTG2.5
Richard
Def ntg2.5 - mine below.
What sort of cost and is it worth it (TV quality wise)?
