After succesfully fitting a CD changer to my Jun 04 CLK 270 Cdi (facelift model), I've decided I'd like to retrofit comand. I have access to WIS and EPC so have looked over the tasks involved and parts required. Comparing this to the brilliant thread "How to fit comand to 208" in the How to Section, my perception is I've got it easy (famous last words). There is presently an Audio 20 unit fitted where the Comand will go.
Anyway firstly the EPC churns out the following additional parts required.
A 203 820 09 75 Antenna
A 211 820 00 88 EL Cable adapter line
A 210 440 50 05 Wiring Harness Only when Aux bushing retrofitted
I'm assuming none are these are "handed" and will fit a RHD car
Part 1 is obviously the antenna, part 2 I presume is an extension cable, and part 3 sounds like the aux input cable and not actually necessary, but maybe worth fittting. Anyway I have several questions for the experts
2 The antenna position in the WIS sheet, shows it above the Inst cluster, towards the right. Is this the best location but should it be towards the centre of the car for RHD, for best sat reception ?
3 Obviously another trip to the stealers and £40 to have the Instrument display activated, but last time the car was programmed to accept the CD changer, will this still work once the Comand unit is fitted ?
4 I will require a Nav DVD, V 6.3 is the latest I believe, but have I missed anything ?
many thanks for any info offered
Midland45
Midland45
