Comand - APS navigation drive connections
Paul Grainger
UK
SL55, Porsche 996 C2 convertible
Hi
Does anyone know the part number for the power connector plug to the remote navigation processor used on an SLK Comand-APS. It will be the same as all 'similar' comand APS systems.
Alternatively, can anyone provide connection details to the nav unit? I can only presume that there will be +12v, Ground and a wake-up line connection, but I haven't got a clue which pins they go to on the nav processor unit.
The MOST and antenna connections are easy (I bought a loom, but it didn't include the actual power connector)
Thanks in anticipation of an answer!
Paul G
I believe pin 2 is power, pin 1 is ground and pin 5 is wake-up.
I did not try to find the connector part number.
Thanks - but the pins aren't numbered - do you know which pin 1 is?
The part number for the connector - if you could find it - would really be very helpful!
Paul
I believe the connector housing part number is A0465450828, contacts springs A0135451526.
DB - Thanks for your help.
The nav is now working perfectly. My next problem is how to re-instate the CAN connections to the AGW.
I removed an ICANI phone interface which had been 'botched in' (quite literally) to the CAN connections at the AGW. Before I removed this interface, the steering wheel controls etc worked fine. Now they don't, and I have a number of wires - some of which are obviously the CAN connections - to reinstate. Unfortunately, it doesn't seem to be colour-to-colour as the wiring has been altered when the ICANI interface was fitted.
Please can someone (hopefully you, DB!) provide connection info for the AGW. The only connection info that I need is for the one including the MOST bus and CAN connections, including the original wire colours.
Thanks again, DB, for your help on this one.
Paul G
