I have recently taken ownership of a mistreated 2006 CLS 320 CDI. Beautiful car, but unfortunately I've uncovered quite a lot of issues (inc. Turbo... - it's been an expensive learning curve!).
I also have some issues inside the motor, and on this topic I wanted to ask for some advice specifically on the Comand APS NTG1 system.
Thanks in advance. Any other tips or tricks would be greatly appreciated!
- The DVD Player - not the changer, but the central main disc slot - any entertainment DVD I try will not play. It says DVD Error or No DVD. The Mercedes Manual DVD however will play, indicating to me there is no issue with the laser? Is it software? Or perhaps entertainment DVDs do not work? In the Engineering Menu, the Region setting is set to Region Free.
- Software - I'm currently on the Europe Green Version 4.1 disc. I am getting an upgrade sent out. I have heard this new disc will then also automatically upgrade the APS software?
- MP3s - do these work in the changer, or in the DVD slot only? I don't have a Disc drive on my Macbook, so I would have to purchase one with spare discs to even attempt this route. Is it worth doing, or would you stick with the Aux/Phone hook up?
- Bluetooth - I am thinking I'll not even bother. I can't believe you have to buy a £300 module to enable Bluetooth. Is there any major benefit to do so? I was thinking the alternative was just use the Aux cable, calls will still go through the speaker, I lose the button functionality on wheel and Contacts on screen though.
- Video Input - I read that this unit has a Rear Video Camera interface - has anyone attempted this and if so, was it worth the effort? Does it engage with Reverse gear?
