Comand error code B1767
sjmaxwell
Chatham, Kent
2012 E Class E63 PPP, 2012 SLK55 AMG
After having the error list reset on my Comand, it has come up with B1767, although everything seems to work ok.
Anyone know what this error code of B1767 means?
hash
oxford
Audi A8 08 with lots of toys & volvo XC90
hi are you sure it is b1767? not seen that before
kenny
clegsr
London SW16
Later
if its any consolation my COMAND has these two error codes which also aren't on the list:
B1010 and B1762.
..I feel a trip to the stealership coming on, I might have to sit down until the feeling goes away.
OP
OP
sjmaxwell
sjmaxwell
Chatham, Kent
Was your Comand a factory fitted option?
hash
oxford
hi B1762 is a can communication error, you will get this if the install was a retrofit.
if it all works dont worry. no idea on B 1010
cheers
kenny
clegsr
London SW16
Later
Its definitely NOT a retrofit, but its not feeling very well at the moment - the multifunction display is not quite right and it sometimes doesn't wake up properly on ignition - the stealer has promised a software update as its still under warranty.
OP
OP
sjmaxwell
sjmaxwell
Chatham, Kent
Ok, so it's normal for Comand to have error messages! So what is B1767?
