MBenzNL
every single OEM MB GPS antenna comes with that same wicklick connector...the 203, 209 and 230 partnumbered GPS antenna are all alike with the only difference that the cable is a bit shorter for the 209 antenna and a lot shorter for the 230 antenna...but they do all use the same wicklick antenna - so you had to use that extension cable anyways.Originally posted by Flyer
I ordered the wrong one - 203 820 09 75, instead of 230 820 08 75. I therefore had to also buy an extension cable (203 540 70 06), as the connectors are different
The shape is different as well...the 230 numbered comands ONLY fit and work in the R230 SL and that is it...the 209, 203 and 463 (with additional speedwire) are interchangeable and same shape.Originally posted by Steve bcs
Conversley the C & CLK (& G class ) whilst the same phsical shape, will definately NOT work in an SL
greetingz,
