COMAND NTG 5s1RETROFIT from NGT4.5 Audio 20 ML 350 W166
Hello.
I need your help. I changed my NTG4.7 to NTG5s1 and I already put the unlock code and everything, however, the same problem as you, the antenna cable is connected but this message appears. How did you resolve? I have access to Vediamo.
You have problem with variant coding I spend a lot of time with vediamo to change coding to my car.
it's done. it already works. The original car radio had the digital system and I don't. Now I have another problem, nothing appears on the instrument panel when playing a song through SD card or an original CD. The radio station appears normally. What could be the problem now?
The instrument cluster is too old. You need to update the firmware/software or if this does not work to find a newer instrument cluster
