DaveML270
I am so glad that I discovered this forum and am able to benefit from the combined experience of all the members!
I thought that I should go public with this as I feel guilty about keep asking Alfie for advice by PM! I am so grateful to him for all his help!
Anyway ... this is the situation. I have a pre-facelift ML270 CDI (W163) and decided to go for a self-retrofit COMAND 2.0 (PN A 163 820 36 89) which I purchased privately from a guy who sells loads of satnav stuff on eBay.
With Alfie's guidance I installed it yesterday and apart from a few problems with the previously installed HCB-30 Bluetooth hands-free kit and the Kit4Cars radio mute module it was a breeze! I had to chop a bit of plastic out of the double DIN hole but that was all.
The unit appears to have the MY2001 update fitted in that I see the MB star on start-up and it offers predictive entry of place names etc. The UK map disc is OLD (from 2001).
So what are my problems?
I can see my current location on the map. But if I enter a destination and try to get a route, then when it is calculated I do not get a route at all but instead I get a message "OFF ROAD" and the voice prompt says "the vehicle is located on a road which is not digitized" (or words to that effect) this is even though I can see my location on the map! It also displays the distance and direction of the destination.
I have also noticed that the map doesn't seem to follow me very quickly as I drive but catches up every minute or two. I am normally able to see between five and eight satellites (the GPS antenna is mounted on top of the dash).
I am anxious to put a quid or two into Alfie's pocket and will order the latest UK and Ireland CD from him but is this likely to fix my problem? What can I do about the moving map display? I understand from reading the plethora of documents about COMAND and retro-fitting it that my model doesn't need a speed wire to be connected but perhaps I have misread the documents.
Any help would be MOST gratefully received and will be faithfully applied!
Thanks in advance
Dave
Thanks in advance
Dave
