evdok said:Hi all,
1) Has any1 copied a command DVD successfully?
2) also when using command is there a way of displaying the total miles left for the trip apart from pressing the info button?
E
Comand 2.0 shows the remaining distance on the (non-map) navigation instructions page, remaining distance and remaining distance to next instruction (usually some junction or other). Remaining time as you say is only on the info page.Alfie said:With Comand 2 you have to use the info button. With comand APS you can select the remaining distance/time on the map display.
Alfie said:Hi,
I believe some people have copied the DVD's and there is at least one person selling illegal copies on that well known auction site. I strongly urge you not to buy or use copies.
fuzzer said:Is that cause they don't work or cause your a teleatlas dealer?
I had a few "backup" discs and when my comand cd head refused to read both music and navigation discs the only thing it would eventually look at was a beaten-up, scratched 2001 original disc!Alfie said:Both.
We find copied disks do not read as quick due to retries/errors.
Alfie said:Both.
fuzzer said:wasnt having a dig , was just curious. Must be the firmware on the laser isnt suited to the wavelength of the CDR's againsed pressed silvers.
