Hi all,
New to the forum and have done a quick search with no luck pin-pointing a command (163) install on a 1999 ML. I wanted to know -
If I buy a 163 Command model will this run my Merc 6 Disk CD
Will I need a cradle or will it fit as is
Where will I get the antenna and leads
Do I need a speed sensor and if so where can you get one.
If anyone has done this swap I would appreciate any advice.
Also ..... from the forum do you rate the command Sat Nav or recommend going for a more modern DVD based Sat Nav/DVD system????
Many thanks,
Joules
Many thanks,
Joules
