Hi guys,
Can anyhelp with the issue im having.
Ive got a 2006 CLK 280 with the built in command system (sat nav etc).
The problem im having is that it keeps turning on and off constantly, i cant turn the volume down or change the radio station... sometimes it settles down and stays on the maps bit but then if i try change to audio it will wont do anything and turn off and on again... its really frustrating!
i opened up the engine bay fuse box and took out fuse 64 but it didnt solve anything...
recently i had a new battery fitted but im not sure whether its to do with that?
any suggestions?
Thank you
any suggestions?
Thank you
