Command Video Input / reverse Camera
thebig1
Mercedes C63
Hi Guys,
I have read that on the rear of the Command unit there is a video Aux connection. its a FAKRA connection.
Does anyone know if this will take a standard video input, i.e NTSC or PAL?
If I activate the reverse camera in the engineering menu, if a say NTSC standard video input is on, will this show on the screen without any other devices required?
So a standard reverse camera, with NTSC connected to this input would work when reverse is engaged?
Hi Guys,
You havnt said which car/comand unit this is but in essence if there is a green Fakra on the rear of the comand then this can be used as an NTSC input from a reverse camera.
Oppps sorry, its a 2013 C63.
So if i purchased a camera, NTSC, connected it to the FAKRA it would work ok?
Also, would the image be mirrored with a standard camera?
When I added a rearview camera to my w204, I needed a firmware update before it would work. Alfie at Comand did the update for me.
My car is in for the full update with Mercedes in a couple of week.
Anyone any idea about if the images on a standard camera will be mirrored?
Probably yes and why would it be mirrored?
