Command
Discussion in 'Electronics' started by BULLITTBOSS, Sep 15, 2011.
  1. BULLITTBOSS
    BULLITTBOSS Active Member
    80
    Apr 20, 2010
    ipswich
    Car:
    r129 500sl
    I recently purchased a gl420 which i am over the moon with with exception to the sat nav system which is ok but not so good as my other car Audi A5 the postcode system only uses 4 digits and only guides you to the actual road not the final destination,WOULD a new disc solve the situation as mine has original 2007 disc or would i be wasting my money??
    Richard
  2. flowrider
    flowrider MB Enthusiast
    2,889
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500 (R230)
    I don't think it will make any difference. I can never understand why a £2000 builtin system is never as good as a £150 portable satnav from Halfords.
    I have had built-in satnav on my last three cars (Jeep, Audio and Mercedes) and they have all been pants compared to my wifes Garmin.
    David
    1 person likes this.
  3. npuk
    npuk MB Enthusiast
    4,239
    Nov 12, 2009
    London
    Car:
    A180 CDI Avantgarde SE (2008)
    No the older units only support 5 digit postcode input, a newer navigation disc wont change this.
    You would need to upgrade the unit to the newer MY09> Comand NTG2.5 which supports full 7 digit postcode input.
  4. Mercy1
    Mercy1 Active Member
    620
    Dec 14, 2010
    Car:
    It's a car - just a car!
    It is amazing that only the very latest Comand versions accept full British postcodes - apparently there are historical reasons for this that have been discussed previously, but in a nutshell MB couldn't be ****d to go that extra mile for British customers...:dk:
    HOWEVER, once you get over the shock, then it is a fact that specific addresses are indeed more accurate than postcodes, and if you use Linguatronic, even easier. So forget postcodes, go for full addresses - and you don't have a problem!!:thumb:
  5. Benzowner
    Benzowner MB Enthusiast
    2,700
    Jun 21, 2004
    Bristol
    Car:
    Qashqai Acenta Premium 1.6Diesel
    :DI don't know why having a full uk postcode helps. My postcode covers 42 properties:D and that is houses not flats, mostly semi detached.
  6. rascalmaster
    rascalmaster MB Enthusiast
    1,407
    May 5, 2010
    harwich, essex. UK
    Car:
    Brabus D5 (E280 CDI) Avantgarde, E280 CDI Sport Estate, E320 Avantgarde now sold
    its because say you're on the phone to someone and then say '' whats your address? i'll just pop it in the sat nav..." very often it's so much simpler to take their post code and then the actual house number, rather then start with the city, then the street then the house number... (of course that doesn't work either because it will ask you to choose from between 31- 69 or 12- 68 :wall bash:
    the mercedes command sat nav is lovely otherwise; the positioning is very precise (you can see this when coming around a large roundabout for instance- it tells you when to take the exit)...
    shame about not having full post code and specific house numbers though.
    also wish it would show you an indication for whats coming next, in advance... such as an arrow and say 2 miles... so you know you have to turn in a while and can adjust for it...
    tomtom i find is absolutely brilliant. good too; how you can customise the display...
  7. flowrider
    2,889
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500 (R230)
    Because inputting a postcode and house number is quicker than entering a full address.
    David
  8. flowrider
    2,889
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500 (R230)
    The only reason to go with the builtin satnav is convenience of always being to hand, other than that a TomTom or Garmin is way better and massively cheaper although looks naff suckered to the windscreen.
    For some reason the Mercedes satnav sometimes decides you are no longer on the route and has you travelling parallel to the road then gets its knickers in a twist trying to get you back onto the road you are already on!
    David
  9. davidjpowell
    davidjpowell MB Enthusiast
    4,895
    Nov 8, 2007
    Doncaster
    Car:
    Range Rover Vogue, Volvo XC60 and crappy Pug 307
    As long as there are not two streets with the same name in the same Post Code 'district'
    Happpened to me a couple of times when driving Mercs with Comand. Had to break out the trusty phone satnav...:eek:
    ETA this was when I had used the 'short' postcode with streetname and number.
    Not sure that a 'full address' would have helped, as from memory that just showed the two streets, with no indication as to where each was.
  10. Merco
    Merco Active Member
    382
    Jul 26, 2010
    London or is it Surrey?
    Car:
    C200 Exec SE Estate
    I bought my car in September 2010 with COMAND and only have the 5-digit input.
  11. flowrider
    2,889
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500 (R230)
    Interestingly mine does do 7 digit postcodes but the past two times I have wanted to use the satnav it hasn't found all of the postcode and I have had to resort to adding the address the long way.
    David
  12. npuk
    npuk MB Enthusiast
    4,239
    Nov 12, 2009
    London
    Car:
    NTG4 only has 5 digit postcode input but I think the new NTG4.5 fitted to W204 facelift has 7 digit postcode input.
  13. Red C220
    Red C220 MB Enthusiast
    4,197
    Jul 30, 2011
    Surrey
    Car:
    2015 SL400 : 2017 S6 Avant
    I have the new Becker Map Pilot, which is just as good as the COMAND (previously owned a 2010 ML300) unit for guidance.
    I bought the unit new for £300 on eBay.
    I can see Mercedes phasing out COMAND, it's just to tough to sell at the price.
  14. Merco
    Merco Active Member
    382
    Jul 26, 2010
    Car:
    C200 Exec SE Estate
    That's interesting as I was under the impression that I had the facelift model and indeed this was confirmed to me by Mercedes at a recent service. I wonder what's going on there then!?
  15. Benzowner
    2,700
    Jun 21, 2004
    Bristol
    Car:
    Another flaw with comand post code entry, my post code is BS30, comand will not let be go beyond BS3 as there is obviously a BS3 area about 8 miles from where I live. I am sure other cities are the same.
  16. Goldfish11
    Goldfish11 Active Member
    846
    Mar 22, 2004
    Car:
    C220 CDI (09/11 - Facelift) & SLK200
    New ComandOnline ntg4.5 in the W204 allows linguatronic entry of full UK postcodes. This is excellent just press the button and shout at the system :D
  17. Merco
    Merco Active Member
    382
    Jul 26, 2010
    Car:
    C200 Exec SE Estate
    Ah, OK - will try it linguatronically(!). I know I can't enter a full postcode manually anyway.
Tags:
Share This Page
