St Ives Velo
- Mar 15, 2016
- S210 E320 cdi
Anyone have an idea of a supplier for the leak off o rings on the Bosch injectors, I've found a supplier of viton rings of the correct dimensions, but the minimum order is for around 260. (incidentally it costs less than replacing the rail from Mercedes)
I replaced the whole leakoff rail a few years ago with brass ones off the internet but they don't do just the seals.
dimensions are : Cross section - 1.3mm x internal dia. 3.5, the diameter of the spigot which it fits on is 3.8mm so ID of 3.5 not absolute.
Someone suggested that the Bosch leak off o rings are all the same but am not convinced.
Rob
Rob
