Philbask
Hi all,
M102 W124 230CE, losing coolant (about 3-4 pints per week!) I have looked when hot, when cold but can see no obvious leak, reasonably new radiator, thermostat plus housing and expansion tank cap. Also when I go to top up, invariably there is still pressure in the system.
I did a compression test, all cylinders at 9 Bar, (oddly manual says 7.5?), however spark plug 4 was tight to remove and discoloured.
Now I know remote diagnostics is more than difficult...... but with the wealth of experience here, would you think head gasket irrespective of the compression test results?
Car runs fine by the way
Cheers, Phil.........
