Compressor Regulator
stats007
Hampshire
575M
I have a 2.5hp 12.5cfm compressor that appears to have sprung a leak in the regulator. Are these serviceable or is it a new regulator job?
Well had to buy a new regulator (pressure switch) as the diaphragm had split however the new one has a union for an 8mm copper pipe fitting and I have a 6mm pipe from the tank :(.
Anyone know where you can get reducers/adaptors etc?
we get ours from our local motor factor.. anything they dont keep we get from a specialist supplier in Nuneaton..
There will be one around you.. yellow pages.
