Condensation in clk w209
Myclk55amg
Mercedes clk 55 amg
Anybody got any ideas on what could help reduce my clk misting up inside? The w209 are absolutely shocking for it apparently, my dad w203 and that was bad too?
sjmaxwell
Chatham, Kent
2012 E Class E63 PPP, 2012 SLK55 AMG
Is your AC working ok? Are the flaps on the climate control system fully functioning?
OP
OP
Myclk55amg
Myclk55amg
Mercedes clk 55 amg
Yeah it's working fine it's more when been parked over night or when it's been raining it's the worst car I've had for condensating up
chubbs111
ledbury
clk270cdi
i personally would check to see if your carpets are wet,i have a 2003 clk and that doesnt condensate
PobodY
Stoke-on-Trent
CLK350 Sport, Nissan GTiR
I've just got a bag of desiccant in the well between the rear seats. - I don't think it's any worse than other cars I've owned (and my mats aren't wet), but I already had the desiccant.
Mostly I don't like the noise of thermotronic trying to clear the windscreen, but it doesn't take too long; even when there's frost and I don't have a scraper.
rifiki
clk 280 Ponton 190
The drain holes on the black plastic under the windscreen wipers may be blocked. Had this problem a few years ago.
GP801
Sussex and Tuscany
2003 W209 CLK, 2005 R171 SLK in UK, 1995 S124 E280 in Italy
Our 203 from new used to steam up all the time. Turned out the flaps were incorrectly fitted so it was in recirculation mode all the time. Apparently there was a service bulletin about this issue to alert the dealers.
Rory
Cheshire, UK
C270CDi Estate (late 2004 facelift model)
Mine has always done it too, although not all the time. Don't use it enough to develop a pattern although it's pretty regular if I leave the car on a cold day and come back an hour or so later. I keep meaning to shut the face-level etc vents and see if that makes a difference but always forget.
Dec
C180,A.
Are you using the AC at all times and all year round?
Dec
OP
OP
Myclk55amg
Myclk55amg
Mercedes clk 55 amg
I can honestly say that my mats aren't wet and do not have a leak!. I also know that I'm not using my air conditioning is not on all the time, cheers for help though guys
Dec
C180,A.
If your AC is working properly, use it all the time and see if things improve, doesn’t matter if the heating is on hot or cold setting.
Mercedes recommend using the AC all the time to prevent windows steaming up.
Dec
rifiki
clk 280 Ponton 190
If the mats are not wet the drain holes are ok. I have the AC on about 90% of the time and no steaming windows and I keep the same settings all year round.
clk320x
Hardcore MB Enthusiast
East Midlands
W212 E250 CDI Sport - S211 E320 CDI Avantgarde - S203 C32 AMG
Did you check the rubber window seals aren't letting water in? Check if the front carpets are damp?
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
Check under the carpets in the footwells, surface may well be dry but the underfelt could be sodden.
OP
OP
Myclk55amg
Myclk55amg
Mercedes clk 55 amg
Cheers all for your advice
OP
OP
Myclk55amg
Myclk55amg
Mercedes clk 55 amg
Yeah I've checked the carpets and under the carpets everything is as dry as a bone, going to try using the a/c more often see if this helps
Codger49
South Kent
W209 CLK500, W168 A190; E46 325i; SPA2 XC60
Its a good idea to have a/c on all the time.
If you turn it off, then seals are likely to dry out and its expensive to then re-instate your a/c.
Don't ask how I know this.
CLSMark
Banned
Hampshire via Glasgow
Volkswagen Touareg
How do you know this :)
