CONFUSED :S command unit ntg 4
Discussion in 'Electronics' started by abclassw204, Apr 27, 2014.
  1. abclassw204
    abclassw204 New Member
    2
    Apr 27, 2014
    Car:
    c class w204 11 plate
    Hi everyone, i have a c class 2011 with the ntg4 unit installed. I was told when i got the car kt has bt audio streaming. I now know it dont come with it set up already but i am unsure reading some posts on here and other sites if the software update allows bt audio to happen.
    Some forums say tweaks in the eng menu are needed i have looked and had no luck and some say it is impossible unless you own a ntg 4.5 system.
    So can bt audio be enabled through software updates or not?
    Also are there any other cool tweaks you can do in the eng menu?
  2. OP
    OP
    abclassw204
    2
    Apr 27, 2014
    Car:
    Also this may be a daft question but how do i store music on the command system?
  3. Alfie
    Alfie Authorised Forum Sponsor Authorised Forum Sponsor
    7,253
    May 5, 2004
    Surrey
    Car:
    W169 A class (loaded)
    BT Audio can be installed if you have the media interface you add the medit interface plus which supports BT Audio.
  4. Alfie
    7,253
    May 5, 2004
    Surrey
    Car:
    Deleted
Share This Page
