littlewimp
Trying to find a connection point for a trickle charger, cant open Boot not even even with the key so looking for some help. Thanks
Just checking how you tried, did you turn the key, whilst holding the key... then operate the outside handle?Trying to find a connection point for a trickle charger, cant open Boot not even even with the key so looking for some help. Thanks
There is no jump point under the bonnet on the E55. I had the same problem recently where my battery was flat and couldn’t gain entry into the boot because my key wouldn’t work.. the way I got in was to put 12v briefly direct to the alternator and have someone to standby with key to press open on the remote... this did work.. you can get to the alternator from the top but is a bit of a bitch to get to... hope this helps
