Peter DLM
- Aug 24, 2007
- Location
- Milton Keynes
- 19 reg CLS 350d, 67 reg AMG GT R Caterham Levante
So it's still correct, I might start using it again. "Roofs" doesn't sound or read right or me.
These minor things are never a problem. Just build it to their silly regs then rip out the cheapo doors once their backs are turned. Same applies to a radiator. Pipe it up to just below the floor then fit it when they're gone. Once you have a building certificate they'll never be back and only an eagle eyed surveyor would notice if you ever came to sell.
Confused you ... Apparently if you build the conservatory to building regs you can have a radiator and no internal doors. (ie its more of an extension)
Apparently conservatories otherwise are not considered permenent parts of the building. (therefore not allowed central heating and must have a door between to the house)
In this case you may find it is not "permitted development", but requires planning permission.
True, almost certainly I believe.
Also if I go for one of these garden room/orangerie type things with less than a certain % of glass then planning is needed too I am told.
Anyone know how long planning takes? Want all this done by mid summer so I can sip Pimms in my new wicker chairs :bannana:
Have a look here at the "interactive house" and at "common projects", there may even be a "mini guide"
That should help determine if you need planning permission. If you do, it will take 8 - 12 weeks from when you submit your application & pay the fee.
There should also be a link there for Building Regulations to determine if that is needed. I stand to be corrected, but I believe you can build a conservatory up to a certain size so long as the glass complies with safety standards and there is an external door between house & conservatory and no heating. As soon as you remove the door, then it is an extension it has to comply with all the regulations and the most difficult one to meet will be heat loss.
Usually, the local authority building control department are very helpful at guiding you through their requirements.
On the planning side, the planning departments are not so consistantly helpfull - depends who you speak to on the day.
edit - note that "Planning" and "Building Regulations" are totally seperate - you may need none, one or both
