I drove to Nottingham and back on Friday and on much of the M5 and M42 the road surface is rough. On anything other than completely smooth roads I could feel the grain of the road surface through the steering wheel, and the edges of every imperfection.
My car is a 2013 CLS with 18" wheels and Goodyear Eagle tyres at 8mm. I would expect a more muted feeling from the road. I feel as if it's got a bit worse in recent months but it's obviously hard to be sure and those roads are not ones I drive often.
Given the age of the car I'm considering replacing all the bushings. A big job of course but I've done it before on another car and I think I can handle it. There doesn't seem to be any other handling problems or noises.
Has anyone else done this and improved the ride quality? Do I need to replace the lot or should I target certain bits (e.g. that big lower bushing at the front or the top shock/strut mounts) Much of the car needs a good coat of rust proofer underneath so I'll be able to do that at the same time.
Thoughts?
Thoughts?
