Hello all
I wanted to check your thoughts on what regular maintenance should be done in lubricating the soft top moving parts as preventative maintenance.
Generally I try and do the following annually:
Apply lithium grease on the hinges which are metal to metal.
Apply silicon grease on moving parts which are metal to rubber.
Apply MB special lubricant to rubber roof seals.
Look forward to your thoughts / advice around soft top lubrication.
