I agree.
I would expect there to be a drain plug on the radiator underneath and on the block under the exhaust manifold on all Mercedes cars, no need to undo any hoses.
As also mentioned both drain and refil with the heater set to hot and the ignition on.
yes there is a plastic plug at bottom of the radiator plus a drain plug on the block, when Ive done this work on my 202 I was trying to open the plug into the block but some friend mechanic suggested me to leave it and to operate only with the radiator, to avoid leakage from the block plug!?
