Transmission Fluid Change
'Don't know if you have Transmission722.4XX or 722.6XX
First Cyrillic diagram is 722.4, drain plug for torque converter is #20
Second Cyrillic diagram is 722.6, drain plug for torque converter is #10
Use the crankshaft nut to turn the engine (AND torque converter) until the
drain plug is at 6:00 O'Clock[ONLY turn engine in direction of normal rotation,
DO Not Turn Backwards!] (HINT: mark the crankshaft pulley with an engine
paint line so it'll be easier to find next time)Use a New Washer on the Torque converter drain plug.
I'm assuming you can R+R the drain plug out of the Transmission pan and
install a New Transmission Filter?Be careful when retorquing the Pan bolts
too much torque can distort the pan and cause leaks.'Crisscross pattern,
Finger tight, then Torque with an inch pound Torque wrench,also Crisscross.
ALso when removing the pan bolts,be on the lookout for ancillary equipment
held on by the same bolts.
When you've buttoned everything back up...fill with nice new clean ATF at the 95%
of capacity level (You're gonna "Ease Up To " the "almost" full mark) Check the level,
drive for about 20 miles to get everything up to Operating Temperature ...Park on a
PERFECTLY flat spot of ground and with your foot on the brake run through all the
gears (Letting them engage) returning to "Park"...Now check the fluid Level and add
smallish amounts until it's near perfectly full.YOU DO NOT WANT TO OVERFILL!
Oh Yeah,The Engineers in Stuttgart want you to use a LEATHER cloth to wipe the
Transmission dipstick so there will be no "Lint" introduced into all those tiny passages.
