Nothing to worry about, ambient temperature is colder this time of year.
You're assuming the temperature gauge is accurate.It should always get to 90c. Mine does
i am given to understand if you run with a properly working 92C thermostat, all things being equal, fuel consumption will be at optimum - made nearly 10% difference on my 648 diesel. previously running at circa 80C - relatively straightforward job - thermostat, sensor and housing complete - less than £30 at mister auto
A150 Petrol ... mine goes to 80 degrees within 10 minutes but nothing more.
Why is it the A Class has 80 degrees at the centre of the clock. Every other car has the gauge hitting 90 degrees as centre?
Mine (M271) is a smidgen over the 80 mark, always has been.
£30 at mister auto ... where is that?
