Copper grease
mr. shr
Pads need changing on my 211.
Will this grease be ok for the rear of the pads or does it need to be the MB stuff?
Read somewhere it needs to be poly or moly or something? :dk:
Yep. The only difference you will notice will be the extra dosh left in you wallet from not buying the Mercedes stuff.
it should be fine.... i use the halfords stuff...no probs
Is there any difference between the two products?
Doesn't there need to be some moly type stuff mentioned in the description as theres a danger of normal grease corroding the caliper because of the alloys within?
The good news is the Halfords stuff also protects against ' seizure' and in these troubled times that has to be a bonus - see other posts re Anti Cuts demos in London for example.
Off to buy some straight away and then have a lie down.
