T
tanuie
Guest
Hi, Am I right in thinking you shouldn't put copper grease on wheel bolts.
As above. Have used a very thin smear on wheel bolts and nuts on every car, regardless of size, as well as on hub face when alloy wheels are fitted. No loosening, no contamination.
Grease = change in clamping force so a no no from me. If manufacturers don't spec it for grease then bad idea to do so IMHO ....
From an engineering purist stance I believe that a grease or other substance applied to a thread will not allow for an entirely correct torque reading.
As to if this matters in real life..................... ,well I have applied copper grease to wheel bolts for some years and have not had a wheel fall off or noticeably loosen.
Do you use a torque wrench when tightening your wheel bolts?
Agree. We actually do tests of this sort of thing at work and moonloops is correct.
Are you able to elaborate? I have read several arguments about bolt stretch, friction, etc etc. The scientific reason against doing so would be interesting.
The torque relies on the surface friction on the thread of the bolt; thread to thread, metal to metal.
If you apply a lubricant to this contact area you lose the surface friction.
The surface area of the contact points between the bolt head and the wheel is also a component of the torque required.The torque relies on the surface friction on the thread of the bolt; thread to thread, metal to metal.
