Just had someone round to look at my cosworth everything is is set up and working fine, but for to much fuel being pumped in through the injectors hense it not starting, change of fuel distributor or somthing else aswell as.
But where is the fuel being delivered from, the injectors or cold start.
If it's the cold start check the warm up regulator, if it's the injectors it has to be the metering head.
The pin maybe moving but is it restricting the flow enough.?
