If I remember from mine;
1. Air filter and inlet pipe off (plastic pipe that goes over the engine)
2. Unbolt the cover plate, top of the engine, allen head bolts, silver in colour,
3. Pull the leads out, there are 2 leads per coil, the coil should remain where it is,
4. A very long extension piece on you socket (12" should do it) to get down into the to where the spark plugs are,
5. Undo the spark plugs, fit new ones, put your engine bay back together
Mark
