Hi. I've not used the forum for a while, but I hope someone can help with this....
I'm trying to replace the crank position sensor in my E320CDi. It is a bit of a s*d to get at if you have big hands!
I have eventually got the bolt out, but the sensor will not budge. I've tried by hand and gently with mole grips (don't want to snap it off).
Is there any reason why I shouldn't squirt Plusgas around it - could it do damage if any went into the flywheel housing?
Thanks.
Thanks.
