Earlier today I took my oil cap off and notice small amount of cream on the cap and a little on the opening. Is that sign of head gasket or condensation. My car is a clk 240 with 102k. Temperature is normal around 90/100
Most likely just condensation which is normal this time of year. If you do a lot of short journeys try and take it for an Italian tune up once a week
Oil floats on water so would settle on the surface in the header tank/there'd be cream/mayonnaise instead of clean coolant in itHow do you know if oils in the coolant thanks
6 - 7 miles, especially if it's in rush hour stop/start traffic, isn't long enough to get everything properly up to temperature let along stay at temp long enough for condensation to evaporate etc. Some engine designs are more prone to mayonnaise from condensation, things like a separate oil filler tube instead of a cap directly into the rocker cover for example. Even old aircooled VW Beetles can be prone to this in cold weather if used for short trips
If the headgasket or some other seal/gasket had gone between oil and waterways then oil in the coolant is more common than water in the oil as the oil pressure is a chunk higher than the coolant pressure. It's the short journeys
What is the riser? Although I can't see oil in the coolant the coolant seems orangy browny colour is that normal? As in June I had a replacement gearbox in aswel as a new radiator etc
If that's all you travel to work & back, then you really should get yourself a bicycle FFS.I do around 6/7miles per day only to work and back
Its the plastic piece which the oil cap sits on. If the coolant had gone that colour its possible someone has used the wrong coolant in the past or possible corrosion in the system. Drain it from the bottom of the radiator and flush it through the resovoir with a hose till its clear out the bottom. OE MB blue coolant is cheap anyways and mix it with water job done
Thank you. Does the riser come off if so how? Thanks
