SEM
- Apr 19, 2004
- Location
- Tamworth, Staffs
- 2007 C220 CDi SPORT & E350 Coupe Sport
Cautionary tale
I used my limiter on a 40mph road with lots of speed cameras. I set it at 35 and took the car a little over… the srs kicked in then packed up causing the car to throw a fit and shut down. I pulled over… turned off the ignition and restarted, everything worked fine but left the srs light on, which I got fixed. I’m frightened to use the limiter now in case it does it again at higher speeds
