classic180
- Jun 30, 2008
- Mercedes c180 2002
Hi, can someone please point me in the right direction. w203 2002 C180 Classic.
Back in March 2008, I had a faulty Pass Side Front Indicator Bulb. I took out the Bulb holder, and there was a small hole on one of the connectors. I had an NCT ((Ireland Test) UK equiv is MOT) in 2 hrs, so I (Stupidily) placed a piece of Tinfoil on same, and bulb worked (New Bulb Holder (STG6 / Euro 8). On my way to a Tyre Centre to get 4 New Tyres, New Rear Camber Strut, and 4 Wheel Alignment (I'm a bit 'Precise' when its comes to my cars - probably didnt need new tyres and Rear Suspension was a little sqeaky only), I engaged the Cruise Control and it Disengaged itself at 50 KMH. I thought nothing of it. Got all the work done, passed the NCT (MOT), BUT Since March 2008 I still have the Cruise Control Problem.
I have Replaced the Brake Light Switch (Although it appears to be a Clutch Switch as there is only 1 Cable and Pin Connector under the dash and it only fits this 'Clutch Switch' which fits over the Clutch. If I fit same over the Brake Pedal - I have NO Cruise AT ALL. Therefore thats not the problem. (Ps Where is the Actual Brake Light Swicth?)
Regarding the New Tyres, (They seem correct Size, Same Thread etc), Regarding the Rear Strut, I dont think it was fitted to well as my Tracking is always off a bit and My Steering Wheel is not 100% Centred.
Therefore, Is my Cruise Control Problem (Again Works Fine betwen 30 and 50 KMH (or 20/25 and 30mph) from:
(1) Brake Light Switch - Where Is It???
(2) The Stupid Act of The Tinfoil - Have I 'Shorted Something' - Is there a Separate Cruise Control AMP / ECU / FUSE??
(3) Are the Tyres a Problem?
(4) The Alignment (from Rear Strut) coupled with the 'Not 100% Straight Steering Wheel' - Is the Affecting the Steering Angle Sensor? Does The 'ECU' / Steering Angle or YAW RATE Sensor think I'm acquaplanning or something similar?
Its driving me made and I wont go to MB (Ridiculous Pricing). Ps. No Faults Showing Up on any VAG Diagnostics.
Please Revert
Classic180
Please Revert
Classic180
