Cruise control W210 1998 E200 CDI Manual
Plamii
Czech Republic
W210 E class 200 cdi
Hey guys,please help.I bought an E class 200 cdi manual 5 speed european version 1998 75KW ,but id doesnt have cruise control.
So i did a lot of research and it seems its not so difficult to install it.Since it is a 1998 model Manual,it doesnt have any plug/cable for the cruise control on the left side beneath the steering wheel or behind the cover.Im not sure but i think, that i can plug the cruise control cable in the ignition ,there are 8 pins that the CC can be plugged in,so is my theory correct?? And if yes,then wich CC part.n should I buy?There are so many of them..I read that if its the correct part number of the CC it doesnt even need coding/activation..
So please help me,any advice will help me a lot,thank you all in advance.
These are the pictures from the ignition with 8 pins, (next to the red cables ) and the type of CC that needs to be put there,but im not sure what part number ,or does it matter?
How does the cruise control work in hilly roads? Never had cruise with manual box.
