C270 CDI
Hi all, I've just picked up a 2003 SL500 and while I'm completely happy with it it seems the cruise control won't work. The stick has the yellow light on which I'm assuming means the limiter is on, and if I press it in to select cruise the light doesn't go out.
Is there an easy way to fix this, or is it best to get a new stick? Would all models of the same year have the same stick, and would it be a simple case of changing it and plugging the replacement one in?
Thanks.
Thanks.
