Cruse control
glowhawk
redditch
E 240 jaguar XKR
Hi my cruise control only works at below 60 mph it used to work at all speeds can anyone help please
Could be your rear tyres are excessively worn compared to the fronts, or vice versa.
What car is it on, I know there's a limit you can set on my ml, you may have pushed the stalk in by accident, that's what I did and the only reason I knew it had one.
If it's a stalk one, push it in and the computer will say the limit figure.
I think it's pushing in, or doing something to it anyway
It's likely tyres . Check size if within your car spec . Uneven wear as well as different tread pattern can cause cruise inactivation due to difference in wheels speed .
Hi yes I know it has a limiter and it is not on I have checked but good idea thanks
First thing to check is that the tyre pressures are correct, an under inflated tyre will cause problems with cruise.
glowhawk said:
Thanks bing will put a couple of tyres on and see if that works
Ok two new tyres on and it's all working again thanks
