The CRX was very competitive last year - running 12 second 1/4 mile times, (not its forte) but being a LOAD of fun on trackdays and in competition.
Current spec is 1600cc and about 360hp with about 300 of those ponies used on trackdays and the rest for 1/4 mile runs
Its biggest plus is that it can be driven by my Wife/Mum for a trip to the shops and is totally tractable around town whilst returning over 40mpg on a run - Almost perfect
We decided it needed to be more powerful for the 1/4 as well as having more mid range grunt to make it more competitive in competition. This is actually a lot more work than just turning the boost up unfortunately as it would make the car less tractable for the road.
The solution was a bigger turbo, but to keep the low end response a bigger 1800cc type R engine (heavily modified internally) was sourced to spin the big turbo up in the same way as the current T35. The new turbo is a spec that I designed, mounted to a modified Neukin manifold and a lot of chopping and cutting courtesy of Dorian T
Eddies rather poor photo
Front end cut away and welded. New turbo clocked, sized & fitted with new manifold, Brackets made and welded in place for the new rad and new large intercooler (not shown)
Old turbo frontpipe is visible beneath the new turbo but this was obviously not going to work with the new setup
Add a bit of Hayward and Scott magic and we have a new exhaust frontpipe
Neukin manifold altered to take a 44mm external Tial
Long screamer pipe on a double skinned expansion slip joint and neatly grafted back into front pipe so we stay inside noise levels on track
They are the improvements needed to remain competitive in the real world, It will never win 1/4 mile prizes but that doesnt matter - its all about the complete package. Nowdays a winning 1/4 mile car will be useless on the road as all 10 sec cars are - this will be a dream on the road and very competitive on the track. It wont be a slouch on the 1/4 mile either
With luck the final parts will arrive next week to complete the 3.2 190's Wiring/Ecu/Coilpack issues and I can get started on the next turbo project
If you are bored with all the FWD shenanigans - too bad for reading this far
Mark
Mark
