D
Deleted member 126251
Guest
You do realise that this is a MB forum.....don't you?The positive , jump start, connection on the BMW and Porsche are perilously close to the underside of the closed bonnet so having to position the clip on connections takes a bit of trial + error , unfortunately the error side of things could result in the + clamp being used as a big fuse should it come into contact with the earthed bonnet.
No untucking / tucking required as i made them as short as possible so just plug / play / forget it until the charger says
K
