Dec 29, 2009 #1 A amolak Active Member Joined Mar 22, 2003 Messages 275 Car B200Turbo & V350 Hi, My drivers side cushion switch is loose. Whilst it moves the seat cushion fine forwards/backwards, the switch itself is loose on the door card. How can these be removed to check and secure. Thanks
Dec 29, 2009 #2 BlackC55 Authorised Forum Sponsor SUPPORTER Joined Feb 8, 2007 Messages 20,782 Location Portsmouth, Hampshire. Car E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up What car?
Dec 29, 2009 #3 OP OP A amolak Active Member Joined Mar 22, 2003 Messages 275 Car B200Turbo & V350 sorry w220 s500
Dec 29, 2009 #4 BlackC55 Authorised Forum Sponsor SUPPORTER Joined Feb 8, 2007 Messages 20,782 Location Portsmouth, Hampshire. Car E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up Is it the button or the switch loose?
Dec 29, 2009 #5 LTD MB Enthusiast SUPPORTER Joined May 21, 2009 Messages 6,134 Location Planet Earth Car Polo GTi (and a travel pass for the train and subway) If it's the switch buttons itself then the upper and lower section of the seat base switch are clipped together. This allows the entire base/pad to be moved as one or the seat pad only leaving the base in position. My guess is that the upper section of the button may have been prized upward to try and tilt the base rather than using the entire button.
Dec 30, 2009 #6 OP OP A amolak Active Member Joined Mar 22, 2003 Messages 275 Car B200Turbo & V350 Hi, its the button itself for the top cushion that is loose. How can I take it off and reseat or do I need a new one.
