tflda29
Evening All,
I am needing to change the outer CV gaitor on my ML270 W163 as i got a bit over enthusiastic with the blow torch when trying to get a snapped front anti roll bar bolt out.
My question is can i just remove hub nut (easier said than done) and then the top and bottom wishbone balljoints and swing the hub out of the way on the track rod end or do i need to remove calliper, disc etc.
thanks
Trevor
thanks
Trevor
