cylinder head on w124 230E 1992
jinja
merc e220
Hi I am new to the forum
I am in process of removing the cylinder head due to gasket blown on 230E 4 cylinder petrol.
I would like the workshop manual if anybody have it . I have tried the link from the forum but that is American model starts from 6 cylinders.
You help much appreciated.
219
MB Club Veteran
Gone
Not always
Haynes do a manual for the W124 which covers your engine .
M102 heads can suffer corrosion and may need skimmed/repaired . The 1.8L version is normally worst for this .
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
Untitled Document
all the data you want on the M102 engine.
IRRC the only tricky bit is removing the top pin on one of the timing chain guides which effectively "stitches" the head to the block at the front. You need a slide hammer or fabricated puller for this
anfieldassasin
Essex
1988 300ce, E46 323ci, 1990 230ce C124 (sold), cl203 180k (other half)
Untitled Document
Grober the links stopped working any chance you can PM or email the pdf, gonna need it for my m102
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
I posted a direct link ,but this general link goes to the online mercedes 190 manual . [ sometimes takes a while to load from the USA] have a look in the section on the M102 engine- same engine.
Untitled Document
If that doesn't work try downloading the entire manual here and then unzip it. http://modtech.us/w201-mercedes-shop-manual.html
