Hi
Old topic with no obvious answer I'm afraid. I've just taken delivery of a 2 year old E220d Cabrio with NTG5.5.
The DAB signal is appalling (very few stations found and even those that are drop out frequently - i.e. every couple of minutes). The FM signal is pretty bad too and only finds a small number of stations. I've seen posts about: firmware updates (not done yet), dashcams or other devices interfering (I don't have anything plugged in); blown/missing fuses (I don't know where to start as I can't find a fuse diagram).
I've also tried a free trial of internet in the car to see if TuneIn works any better. But that often takes several minutes to "connect" (or just as likely, not connect) even though the head unit shows 3G or 4G signal is available.
Any advice on how to debug this? I'm assuming it is an antenna issue but don't know where to start....
