This morning on the way to work I had an issue where under braking and declutching to approach a roundabout ALL the lights on the dash flashed on briefly.
Didn't affect the engine running as far as I could tell - no stutter.
It happened again at the next roundabout but then was fine after that.
I've tried searching for a cause but 'dash lights flash' etc brings up loads of unrelated results.
Wondering if it's a sign battery is on way out, sparks are dodgy or water getting into wiring. Anyone had similar and if so what was the cause/solution?
Thanks in advance...
