Chrishazle
- Nov 13, 2008
- Location
- Nr Ashford, Kent
- 2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
The S204 has thrown a wobbly on me. Car had a good run on Sunday but has not been used since. Looked at the battery condition monitor when I went to the car for the supermarket run, light was amber rather than green but car started OK - except none of the 4 dashboard guages worked (fuel level, temp, speedo and tacho). Headed off and found no indicators, no hazards, auto lock at about 10mph not happening (although switches in drivers door work), also found electric boot release button in drivers door does not work although tailgate opens from the button on the key fob and closes on the tailgate button. 7 miles each way to the supermarket, not sure if the dash illumination (round the dials) was working on the way there but was on the drive home. Checked the condition monitor once home, green light now, but just in case I've put the smart battery charger on, once the battery is fully charge it will switch itself off.
So, after battery voltage too low, next thought is a blown fuse - but which one and where is it? I don't even know where the fuses are, I suspect there's a few in the storage cubbies either side of the boot but have no idea. Is this something I can check - I have spare blade fuses knocking around somewhere - or do I need a mobile auto electrician who knows his way round an MB S204?
TIA for helping!!
TIA for helping!!
