omega1
Hi all,
I've purchased a nextbase 213GW (mixed results so far) and need to wire it in permanently. I need a switched feed from somewhere, the obvious starting point is somewhere in the rear view mirror enclosure.
Question is, is there a suitable switched 12v in there? Power requirements are 1.5A at 5v, I'm not expecting to find 5v there of course, so will need to get it from 12v to 5v which isn't a problem. But current is a consideration even if there were to be a switched source there.
Failing the rear view mirror, what are people doing for there power feeds? Where is the next place to go?
I was thinking running it down the passenger door bit but then where? Where is there a switched power source?
Thanks.
Thanks.
