In some countries it is a legal requirement to have DRL. It's not that you might forget or something as they must turn on automatically without driver intervention.Can you not just put your dipped beams on???
Running around with your headlamps on all day has the small side-effect of burning out your bulbs earlier and effecting your mpg when compared to only using lamps when it's dark. This is why there is some creativity on the part of owners, manufacturers and the aftermarket suppliers.
Well if you normally use your headlamps 50% of the time you are driving but with DRL they're on 100% of the time I would imagine they'd last half as long.How much sooner do the bulbs burn out? How much extra fuel does it use?
You know what you should do?It's more because I might have a requirement to go to Denmark soon, and would be driving.... I know I can just turn them on everytime, but It's the warning buzzer, as they stay on after the engine has been turned off that I want to get rid of.... They are OEM in Denmark, and I think the some states in the USA, so there should be an easy option........
