I have a 55 plate W211 and intermittently have the following problem :
Insert ignition key and turn to I then II and everything powers on ok.
Turn the key and engine ignition and the instrument cluster completely goes off as well as the climate control and the comand system.
If you stop the engine, remove the key and start again it generally all comes up ok.
The local Mercedes dealer says it is something to do with the communication between the ignition barrell unit and the system ( EIS ? ECU ?? ) ad is £150 for the STAR disgnistic and maybe £600 plus £600 for the fix - OUCH !!
Any ideas or suggestions greatly appreciated.
