- Dec 29, 2013
- Location
- Kidderminster Worcestershire UK
- Mercedes W124 260E M103
When did Mercedes think it was a good idea to make calipers with none replacable bleed niples ? anuone ?
They do. They accept the risk as any business does. There is an old mechanic in my area who all of the local trades have been taking their transit vans to for decades for all sorts of work , engine out/brakes, MOT, all sorts. As time has moved on he has not, he has remained old school and now turns down loads of Transit jobs simply because he does not have the skills or technology to service the new stuff. He will retire soon and would rather not take on jobs that he can not do and be sued for any damage/loss of earnings.And glow plugs?
What if an MB dealer or indy breaks a glow plug taking it out?
Who pays to remedy that?
They are replaceable, just MB can’t get it out now it’s snapped off.When did Mercedes think it was a good idea to make calipers with none replacable bleed niples ? anuone ?
Ahh, but it is part of the caliper when you want to justify charging the customer £673 for a new caliper after you've sheared the bleed nipple off, instead of getting a competent machine shop to remove the remains for substantially less money and supplying a new bleed nipple for a couple of pounds.I don't understand how a bleed nipple is part of a caliper.
a $3 easy out would probably do the job.
What happened in the end?????????????????//
The complaint is still with the ombudsman, waiting to hear back from them.
i'll update when I know more
Had a loose one on my E55. Someone heavy handed was on it before and completely stripped the thread. It was a caliper our job but there are bigger nipples available on eBay M12x1.0 vs M10) for literally a fiver. Drill, tap and it’s no different to the original one. Saves getting new calipers when you’re the one to pay for them.
What are you doing for a car in the meantime?
At a push, to keep a car running, the caliper can be bled at the pipe if the caliper is removed and oriented such that the pipe entry is at the highest point. A bodge, but keeps you moving (and stopping).
CarefullyHow is that done without damaging the taper seat the nipple has to seal against?
